Better Bluetooth Streaming
#132
My Ride: 2008 528i, Dynamic Drive, Active Steering, Nav, Adaptive Xenon, Comfort Seats
![](http://zoppp.net/screenshots/2016/03/Hra2lU3.jpg)
YOU MUST WIRE GROUND. In that picture above, ground was not wired, if you do not wire ground, the sound quality will be very bad.
When I first tried this, I complained the audio quality was really bad but that was because my ground connection was not good at all.
#133
My Ride: 535XI
Engine: N54
You should be able to remove that module and inside you should find a similar aux module like in our rear console aux. Get a multimeter and check which channel is left, right and ground.
So i have to take out the aux part and open it up?
#134
#136
My Ride: BMW 530d M Sport 2008
i have the bmw 530d m sport 2008 with professional sat nav and only the AUX port between the seats but no usb.
my cd player reads mp3 files and tracks from the 6 cd magazine.
aux port works ..but the sound is terrible ..static and some strange noise from time to time anyway..
i want to do your mod but i`m a bit scare and not very confident to do it so i need your guidance please..
i bought the BT board Bluetooth 4.0 receiver high quality stereo audio SURE ELECTRONICS wireless Mp3 i | eBay
what else i need to make it work?
i got he soldering gun https://www.amazon.co.uk/gp/product/...A27I9PUC3YADPK
i got RCA cables
do i need anything else ??
Thank you for your time..appreciate your help
i got RCA cables
#137
My Ride: 2008 6MT M-sport 550i
i got RCA cables
i got RCA cables
#138
sorry if sounds stupid but i`m new to this..
Thank you..
#139
Run power and ground to the BT board to the designated terminals to power it. I used the switched 12v source for one of the rear cigarette lighter ports for power. Then take the factory aux plug off the panel so that it is free back there and unaccessible when the panel is reassembled. Connect the BT reciever to the factory aux port using an aux cable. Tuck/secure the BT board and aux cable and any other wiring in the compartment and then pop the panel back into place. Of course connect your phone to the board and test it out before your reassemble everything.
#140
Thank you..that was the plan i was thinking on..i get my parts and get to work..
doing this ..can i still if i want to connect my phone and stream music trough bluetooth?
will this allow me to connect my music from the phone with iDrive?
