Any info on Bluetooth availability in US?
Guest
Posts: n/a
According to all information supplied, blue-tooth should be avail at launch. Also in the % series brochure, the centerfold page of the rear half of the book shows the i drive system, and it only says that the Nav system is yet to be determined. It lists blue-tooth as avail. The only -major- options that I know of that are not avail at launch are the Nav and the HUD.
Mike
Mike
Mike
Mike
rodybmw
Guest
Posts: n/a
Hi rody,
Yes I am talking about the US. Like I said it is listed in the actual 5 series brochure. You are correct though, that it is not listed anywhere else. The only thing I can find remotely related is: Pre-wiring for BMW center installation of BMW 6-CD changer and BMW mobile telephone (if so equipped). So I assume it has the wiring for the all of it, and what I have read is that the only thing that you will need is the cradle for your specific phone, which I am sure will be added as an available accessory for which you will have to pay ($75.00 or so for the cradle) I know it is available for 2 phones so far. The Sony Ericson T-39 (which I have) and one other.
Mike
Mike
Guest
Posts: n/a
Mike,
does this mean that if one orders a car without the Logic7/CDchanger package, the car still comes pre-wired for a 6CD changer...allowing the owner to buy a cradle/changer and add later ?
if so, is this pre-wire location still in-dash or is it in the trunk ?
Thanks.
Thanks.
boozooface
Bluetooth & Cell Phone Forum
07-29-2015 06:56 AM
Brada Wheels
07-16-2015 06:52 AM
