7130e volume problem
My Ride: '08 550i, carbon black, sport package
Before I pair with the e60 and while on a call, I can use the trackwheel to adjust the volume.
When my 7130e is paired with the e60, and I make or receive a call, the volume function on the handset will not work. I think this is normal.
Here is the problem: Once the phone is un-paired from the e60, I still can't adjust the ear volume while on a call using the handset.
The only way to fix this is to remove the battery. :thumbsdown:
Verizon wireless can't help and won't sent me on to RIM support.
Anyone else have this issue?
My Ride: 520d M-sport, Visibility pack, Cream Beige Leather, Auto, M rear spoiler, BT Car kit, Folding Mirrors, USB, Business NAV, DAB, High Beam Assist, CD Changer, 172 Alloys, Comfort Seats.
I think you mean when you leave the car the volume wheel still does not work?
as a test have you tried switching off the bluetooth in the phone menu when you leave the car? I had a similar problem with a UK spec 7100 on O2, I did a firmware update which solved the problem.
P.S. I would even try a firmware update with the same version of software if you can't find a later version.
Note: a firmware update will require a reconfig with either the internet accounts or the BES.
Regards,
Paul
