550i: Bluetooth issues (cellphone)
I have a BMW approved Motorola cell phone that works well with the Bluetooth wireless network integrated into the sound system of my 550i...most of the time.
The biggest headache I have with this system (over the past year) is that sometimes the person I call cannot hear me, even though I can hear them perfectly. I have tried to fix this problem by disconnecting the Bluetooth connection with the phone using iDrive (unchecking the box), and then rechecking the box--which resets the connection between the phone and the car. Sometimes I will turn the phone off and turn it back on, and sometimes I'll just call back. Each of these approaches has not necessarily fixed the problem--and sometimes it does!
I don't know whether this is simply a random problem that I just have to deal with from time to time or if there is indeed a permanent solution.
Is anybody else having this problem? What do you do about it?
My Ride: E90 M3
Model Year: 2011
Also go into the setting menu of the phone and update the software, does it over the cell network and takes a couple of minutes. May or may not be the issue but it is a quick fix if it is.
