CampioniShop: JIC Cross products
Old Feb 27, 2010 | 11:30 AM
CampioniShop's Avatar
CampioniShop is proud to bring to the E60.net/5series.net community the JIC CROSS line of products for the E60, this includes full competition coilovers and exhaust systems in 304SS and 304SS with Ti. tips.
CROSS Competition coilover systems for the High Performance BMW E60
CROSS Competition coilover systems for the High Performance BMW. The Competition Series is our top of the line coilover system. It features a lightweight design with a 15 way dampening adjustable monotube damper. With its high strength and durability, the Competition Series insures that it will last through any type of driving condition. The front damper features a 40 mm piston and the rear has either a 40 or 45mm piston depending on application. The ride height adjustability is independent from the spring perch so adjusting ride height does not compromise the spring rate or rebound and compression of the damper. All coilover systems come with a cool bend linear spring that offer last precision steering and handling. Spring rates are also custom tailored to each system and driver's preference. All Competition Series coilovers include front camber adjustable pillow ball upper mounts and most rear includes pillow ball mounts depending on application. Larger luxury vehicles have a softer damper for a sporty luxury feel and also allowing a lower ride height. Based off of racing technology, the Competition Series Coilover is a street performance suspension, customizable for full track use.
  • Pillow Ball Upper Mounts
  • Adjustable Dampening
  • Cool Bend Linear Spring
  • Durable Monotube Design
  • High Strength Inverted Montotube
  • Adjustable Lower Bracket
  • Helper Spring
Note: Does not fit XI models.
Front spring rate: 10kg
Rear spring rate: 8kg
MSRP: $2,747.80
Special: PM us
CROSS Exhaust Systems for E60 I6 models 525i 528i 530i
CROSS Exhaust Systems are made of lightweight stainless steel. Weighing in just between 22-29 lbs. these exhausts systems are the lightest stainless steel models on the market. Power to weight ratio is realized due to the massive weight savings that the exhaust offers. Also larger piping and thinner walls aid in power. Built utilizing the latest state-of-the-art equipment with larger diameter piping and smooth bends realize true power gains with a sportier exhaust tone.
Tip size: 80mm
Piping diameter: 76.3mm
Stainless steel:
MSRP: $828
Special: PM us
Stainless steel with Ti. tips:
MSRP: $822
Special: PM us
Old Sep 20, 2010 | 02:02 PM
xavier@campionishop.com's Avatar
For more information call at: 718-504-7497
PMorganRacing
E39 Discussion
Sep 28, 2015 09:49 AM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
