CampioniShop: Forgestar wheels
CampioniShop presents Forgestar wheels. An exciting new company that debuted in 2009 with exciting new designs, manufacturing technology and unmatched pricing!
About Forgestar:
Introducing the World's 1st 1 piece lightweight flow formed wheel lineup.
1 piece flow formed wheels
Lightweight
Clears big brake kit
Great range of offsets
Same Technology Used on Formula 1 and Indy Cars
Available in 18", 19" and 20"
Available finish: Gunmetal, Gold, Matte black, Piano black
Custom made: 2 - 4 weeks lead time
Forgestar's recommend sizing:
Front: 19x8.5 +20 ET
Rear: 19x10 +20 ET
Weights (will vary slightly depending on offset):
19x8.5: 22.5 lbs
19x10: 24.7 lbs
20x8.5: 24.4lbs
20×10.5 25.4 lbs
F14 Pricing:
MSRP 19": $1860
Special: $1400
MSRP 18": $1600
Special: $1200
MSRP 20": $2400
Special: $1700
F05 Pricing:
MSRP 19": $1600
Special: $1200
F10 Pricing:
MSRP 20": $2460
Special: $1740
NOTE:The F14 wheels are also available in full FORGED construction!
Customization of your wheels:
Pin strip: $160 per set
Karbon finish: $1000 per set
FLOW-FORMING
Forgestar's flowforming process is a unique solution to a common problem ? how to make a wheel both light and strong.
This specialized process begins with a low pressure type of casting and uses a special machine that spins the initial casting, heats the outer portion of the casting and then uses steel rollers pressed against the rim area to pull the rim to its final width and shape. The combination of the heat, pressure and spinning create a rim area with the strength similar to a forged wheel. During Flow Forming, the pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel. The resulting grain structure within the alloy of the wheel is linear, flowing in a single direction.
This grain structure pattern, combined with the exceptional quality of casting required for the process, gives the rim area of the wheel huge mechanical strength, and elongation. As a result of these mechanical characteristics, Forgestar is able to reduce the thickness of the rim area resulting in reduced weight, without compromising strength and resistance to impact.
19? Forgestar F14 finished in hyper silver
19? Forgestar F05 finished in Gunmetal with a Machined Lip
20? Forgestar F10 finished in Piano Black with Hyper Polish Lip
About Forgestar:
Lightweight
Rear: 19x10 +20 ET
19x8.5: 22.5 lbs
19x10: 24.7 lbs
20x8.5: 24.4lbs
20×10.5 25.4 lbs
F14 Pricing:
MSRP 19": $1860
Special: $1400
MSRP 18": $1600
Special: $1200
MSRP 20": $2400
Special: $1700
F05 Pricing:
MSRP 19": $1600
Special: $1200
F10 Pricing:
MSRP 20": $2460
Special: $1740
FLOW-FORMING
