Why does Cold Air Intake not good for our cars?
Old Feb 5, 2010 | 02:39 PM
louiemC's Avatar
My Ride: 2006 BMW 650i
why is not good for our cars? Cold Air intakes?
Old Feb 5, 2010 | 02:44 PM
Krozi's Avatar
Because the engineers at BMW know how to make good airboxes. That's really all there is to it...most CAI's heat soak.
Old Feb 5, 2010 | 04:50 PM
tbal's Avatar
My Ride: See sig :)
What he said...
The Afe intake LOST hp... lol
Old Feb 5, 2010 | 05:29 PM
zhuskers1's Avatar
Originally Posted by tbal
What he said...
Wow!!!
I wish I would have known that before I installed an AFE.
I have had one installed for about a year and half (4000 miles).
I have not had it dyno'd, but it sure feels like it has more acceleration. It has a great sound when you put your foot in it. I went with the dry filter option due to the reported MAF sensor issues.
This is what AFE sent me before I ordered:
BMW 6 Series E60 650i
aFe Intake Kit (Stage II)
Part number: 54-11142
Application: E63/64 2006-2008 650i
Description:
aFe Magnum FORCE Stage 2 Cold Air Intake System for 550i and 650i (E60/E63).
11.75 hp and 10.50 lb/ft torque gain!
This intake kit replaces your restrictive factory air box. It features a 3-angle velocity stack adapter, heat-block molded intake tube, 16-gauge powder-coated steel heat shield, trim sealed to seal out hot engine air, and a custom aFe brand cotton filter.
By removing your stock intake air box, you are removing the most restrictive portion of your V8's intake system, increasing both horse power and torque, improving acceleration as well as throttle response.
11.75 hp gain at 5900 rpm
10.50 lb/ft torque at 4000rpm
Old Feb 5, 2010 | 05:53 PM
Krozi's Avatar
This is how aFe gets their numbers: they run it on the dyno once...when the engine bay is nice and cold...with the hood open. After one or
two runs, the engine bay gets heat soaked and you loose HP.
Old Feb 6, 2010 | 08:11 AM
louiemC's Avatar
Thanks very helpful guys. i was about to buy that AFe Intake thing.
What kind of Intake can i install on my car? Dinan High flow intake only?
Old Feb 6, 2010 | 10:10 AM
dbae1978's Avatar
Go with the stock box, bmc drop in filter and race precision scoops
Old Feb 6, 2010 | 10:11 AM
Krozi's Avatar
Yea the Dinan one seems to be the only one that makes actual power, combined with RPi scoops it should make some nice gains
Member brabusw209amg made a "replica" Dinan intake on his 545i and it seems to work
Old Feb 6, 2010 | 10:58 AM
zhuskers1's Avatar
I have a 2008 6501 coupe. There is a 4 to 41/2 inch hose that ports to the front of the car to pull in cool air into the OEM air filter box. It ports to the driver side grill. When I installed my AFE, I left that Hose in place. It pushs cool air from outside the engine bay directly onto the AFE filter. This should reduce/minimize the "heat soaking" issue at cruising speed.
With that said -- you are correct that the OEM box pulls all of its air from outside the engine bay.
I am not an expert on this topic, but the OEM box has to be more restrictive than a AFE or cone shaped filter.
Old Feb 6, 2010 | 11:05 AM
zhuskers1's Avatar
The 2008 650i has a hose that runs from the OEM box to the front of the vehicle. Do you add the RP scoops in addition to the OEM hose?
