boot won't open, any help please
My Ride: E60 M5
Hi guys,
My boot/trunk will only open if 1, you hold the pop button on the key, or 2, enter the key under the rear badge?? The boot pop button in the front side kick panel does nothing, and filpping the badge lever on the boot does nothing (when its unlocked of course)
I've checked the connections at the pop button in the side kick panel.
Can anyone help me with this??
My Ride: 2004 BMW 645 black sapphire metallic, 19" Style 166 (245/40 & 285/35 w 15mm spacers)
Check for key position in center storage compartment. It is possible to block trunk opening from badge and inside by turning the lock in the storage compartment. At least it was the problem in my case
Originally Posted by alpinaandy' post='849039' date='Apr 16 2009, 11:24 AM
Hi guys,
Thanks, glad it worked. Even my dealer didn't know that so I had to figure it out myself
Cheers
Cheers
Originally Posted by alpinaandy' post='849105' date='Apr 16 2009, 02:30 PM
You are a legend my friend. it was exactly that!
thanks a lot
thanks a lot
ucsbwsr
09-19-2015 10:58 AM
