BMW 5 Series Wheel Swap: Which Rollers Will Fit?
Your BMW can take on a whole new look with different wheels, provided that the offset is right.
There is a myriad of ways to give your BMW 5 Series a unique look, but the easiest addition is a new set of wheels. The problem with swapping to unique wheels is that not every wheel will fit on the car without rubbing. That leads many people to come to the forum to ask if a specific set of wheels if they will fit on their BMW.
Fortunately, 5Series.net forum member “JayArras” put together a quick post explaining the key numbers in figuring out whether a certain set of wheels will safely bolt up to your BMW sedan.
BMW Wheel Fitment Introduction
When the OP shared his information with the forum, he provided a concise explanation of wheel offset, which is the biggest obstacle in applying aftermarket wheels to your BMW 5 Series, or any other vehicle.
“I often see questions on the forum from people who are wondering if the particular wheels that they have will fit on their car. A major source of confusion is offset, commonly referred to as “ET”. Hopefully, the following explanation will help clarify this topic.
-The smaller the offset number, the more the wheels will stick out. Conversely, the larger the number, the more they will be more tucked in.
-The ET offset numbers are in millimeters (mms), so going from say, ET34 to ET44 will tuck the wheel in 10 mms (about 0.4″) or from ET44 to ET34 they will push them out about 10mms.
-Rims with too low an offset can cause troubles with the outside edge of the tire rubbing on the fender or wheel well. Rims with too high an offset can cause troubles with the inside edge of the tire rubbing on the suspension or wheel well.
-In the example above, 1/2″ shouldn’t matter much, but it does get a little tricky if the tire used is also wider than the old setup.
-Wheels with too high an offset can be fixed with spacers. Wheels with too low an offset are SOL — you have to roll the fenders to keep them from rubbing.
Hopefully that helps! Two sites where you can find useful information concerning the differences between two sets of wheels are:
–https://tiresize.com/wheel-offset-calculator/
–https://www.willtheyfit.com/”
Other Things to Consider
If you are buying aftermarket wheels or take-offs from some other model BMW, offset is the key obstacle, but it is not the only number you to check. You need to make sure that the bolt pattern of the wheel matches the bolt pattern on your car. If you are going to a markedly larger wheel, you will want to make sure that the package fits inside the fender.
Finally, depending on local laws, you will need to make sure that the wheels don’t extend too far outside of the body. That can be dangerous and it is illegal in some places.
If you have any questions about wheel fitment for your BMW 5 Series, click here to ask in the thread.
Images: BMW Media
