Reduced engine power after braking hard
Old 03-14-2021, 11:57 AM
msportwagon's Avatar
My Ride: 2010 E61
Default Reduced engine power after braking hard
I got this message after bedding new brakes in. After the third hard stop it came on. the codes are: 2a82, 2DED and C2F2. Any suggestions? Vanos maybe
Old 03-14-2021, 12:57 PM
donpb's Avatar
My Ride: '06 530i N52
Clear the codes and see if they return, with no hard braking.
Old 03-14-2021, 01:49 PM
My Ride: 2010 E61
I did. This happened once before. I had to slam on my brakes, other driver blew a stop sign.
Old 03-14-2021, 07:11 PM
donpb's Avatar
Does the reduced power notification ever clear though? With that notification, I'd expect to see more codes thrown. When was your last tune up? What does your battery histogram show?
Old 03-15-2021, 11:47 AM
My Ride: 2010 E61
The notification goes away once the car is restarted. I just replaced the spark plugs. I have a 29e1 intermittent code (I already know my # 6 cylinder injector leaks). I dont have the battery histogram
Old 03-15-2021, 12:12 PM
donpb's Avatar
I thought you just did brakes and nothing else. Changing spark plugs makes more sense. Allow me to explain my experience.... I had that malfunction when I changed my plugs. Nothing helpful showed up on the BMW codes and I was sure the problem was the plugs because I just changed them. Then I checked the OBD2 codes and found the error pointing to the plugs (misfire).
So I go back in and re-inspect my plugs (oh I didn't put it all back together as its best to run the car for a bit before doing all that) ok so I get to the cylinder in question and don't quite see anything out of the ordinary at first. I look closer and see the retaining clip on the coil pack is like a half of a millimeter unseated. I'm like naw, that can't be it.
I said, well let me re-seat it flush like all of the other coil packs. I doubt its the problem, but lemme try it. Well wouldn't you know, that fixed the problem.
Old 03-15-2021, 12:24 PM
My Ride: 2010 E61
The spark plugs were done a couple of months ago. The brakes are recent. The issue only occurred now twice, once when I first got the car and now. I never got the reduced power under other driving conditions, even after an MHD tune and doing some hard pulls.
Old 03-15-2021, 02:50 PM
donpb's Avatar
But something could now be moving out of place by inertia, just enough to cause a problem.
Old 03-16-2021, 03:21 AM
My Ride: 2010 E61
that very well maybe
Danny Livingstone
02-06-2015 03:47 AM
06BMW550i
E60 M5 Discussion
02-05-2014 05:41 PM
Fox
12-02-2010 08:04 AM
ivan545
01-21-2008 12:11 AM
kkte
06-19-2006 02:46 AM
Quick Reply: Reduced engine power after braking hard
