retrofit m5 heated steering wheel
My Ride: BMW e60 525Da LCI White, DPF out, Front grill black, Shadow line, license plate super bright led, interior white leds;
Hello everyone, i installed an m5 steering wheel with fullt functional paddles and i see that he has heat option and i read in some users retrofited but i the don''t specified the details, i search at diagrams but i can't find something useful, any body knows?
thank you for your help
I see that i have separated connections for heat steering
My Ride: 2008 550i M-sport, retrofitted heated M-sport steering wheel with paddles, Sport-auto transmission
Check the part numbers for the SZL and coil spring pack to make sure yours support the heat function. I did the retrofit to heated when I added SAT/paddles and I believe those were the extra parts (as well as the switch assembly that has the on/off switch for the heat).
but to see the number i have to remove the whole steering wheel, you know that connections is for heated? you can remove the airbag please to see what connectiones you have please,
i find out of realoem a picture with heated coil spring but i can't tell 100% sure of the back connections, from up look the same...
still in progres to retrofit the steering wheel but no ideas...anyone??
Ms frumos, i-am dat astept email si te tin la curent.
I send the mail, thank you.
My Ride: 535D lci E61
heater
Hello, im happy to find someone who fitted heated wheel, can you please tell me where to fit connection in spring ? photo would be best, i want to see that wires from heating. (where are coming temp sensor and where is connected heat element.
many thanks.
many thanks.
TexaZ3
05-06-2015 09:54 AM
