retrofit m5 heated steering wheel
Hello everyone, i installed an m5 steering wheel with fullt functional paddles and i see that he has heat option and i read in some users retrofited but i the don''t specified the details, i search at diagrams but i can't find something useful, any body knows?
thank you for your help |
1 Attachment(s)
I see that i have separated connections for heat steering
you prolly need a M5 wheel from 2008+ before that (at least like my 2006 M5) it wasnt an option here in the states...
Originally Posted by umichchris
(Post 1508124)
Check the part numbers for the SZL and coil spring pack to make sure yours support the heat function. I did the retrofit to heated when I added SAT/paddles and I believe those were the extra parts (as well as the switch assembly that has the on/off switch for the heat).
2 Attachment(s)
but to see the number i have to remove the whole steering wheel, you know that connections is for heated? you can remove the airbag please to see what connectiones you have please,
i find out of realoem a picture with heated coil spring but i can't tell 100% sure of the back connections, from up look the same... |
still in progres to retrofit the steering wheel but no ideas...anyone??
Ms frumos, i-am dat astept email si te tin la curent.
I send the mail, thank you. |
heater
Hello, im happy to find someone who fitted heated wheel, can you please tell me where to fit connection in spring ? photo would be best, i want to see that wires from heating. (where are coming temp sensor and where is connected heat element.
many thanks. |
