E39 Discussion Anything and everything to do with the E39 (1997 - 2003) 5 series!
EWS Problems Heeeeelp Please!!!
Old 10-09-2015, 05:41 AM
LouE39's Avatar
My Ride: E39 525 TDS
Default EWS Problems Heeeeelp Please!!!
Hi All
I hope somebody can help.
I was cleaning up errors with on my car with PA soft, because I had replaced a abs sensor.
I also found an error on the ews, so I went into the ews option, coding and then into settings and manufacturer data, and now beguines the stupidity , and don't ask me why but on the DME/DDE Interface I changed ews 2 to ews 3, thinking if anything whet wrong I could change it back, I found out that you can’t change it back.
Well now the car won’t start and I can’t change it back to ews 2 because the option is in light grey and want let me press on it.
So I went in to the ews with NCSEXPER, I found that the ews had "EWS_3_SCHNITTSTELLE" is set to "aktiv", but should be set to "nicht_aktiv"
I tried changing it but I get the following error
Could anyone help me out???
norsecarnut
06-27-2015 05:47 PM
ETNav382
04-24-2015 07:29 PM
wrx5
03-29-2015 04:53 PM
das
Site Comments & Suggestions
05-31-2004 03:12 AM
rodybmw
09-01-2003 02:03 PM
Quick Reply: EWS Problems Heeeeelp Please!!!
