E34/E28/E12 Discussion Discuss the E34 (1989 - 1996), E28 (1982 - 1988) and the E12 (1972 - 1981) 5 series models here.
Johnny B
Old 09-26-2015, 09:05 AM
Johnny B's Avatar
My Ride: 1995BMW 540i
Default Johnny B
Hi, I am having nothing but trouble with this whole "forum" series !!!! I know it is no doubt my "tech savvy" or more the lack of it ha ha, but perservere I will and eventually , hopefully, maybe, possibly yadda yadda ya, I will get the answer. (can't even get my backspace to work today ) Anyway I was able to get another key for my 1995 BMW 540i 6 Spd. I had misplaced the original (remote) key and the dealer (450 K away) was able to find me a replacement key. The difference is the replacement key is not a "remote' key so the electric door locks don't work of course. THE PROBLEM is apparently because I do not have the "remote" key as soon as I attempt to start the vehicle the alarm is triggered and the starter motor apparently is disconnected. Therefore I am left sitting there with the alarm beeping and no power!!!!! Somewhere I read that there was a "blue" fuse, switch, connector or something under the rear seat that would disconnect the alarm system. I am not sure of anything after that and am hesitant to start disconnecting wires knowing the problems that could cause with the electrical system. Can ANYONE HELP """" I have just spend a small fortune on this beauty having it repainted, new mouldings, etc etc etc and there it sits gathering dust in my driveway. Help please!!!!!
Old 09-26-2015, 03:44 PM
Admin Emeritus
speedlimit's Avatar
My Ride: BMW F13 640i M Sport
Model Year: 2015
Engine: 315-hp 3.0-liter
Hi,
I moved your post with the hope someone will be able to help.
Bob
Old 09-27-2015, 06:29 AM
DanL's Avatar
My Ride: 535i M Sport
Model Year: 2010
Originally Posted by speedlimit
Hi,
Bob
Well, still the wrong forum since the OP has an E34, not an E60, so the thread probably needs to be moved again.
OP, removing / disabling the alarm won't fix your problem, you need to bypass the immobilizer system (EWS) and that's very difficult -- assuming it's even possible. The answer to your question may depend on when your car was manufactured and what EWS version you have. A quick Google search returned the following and the page I copied it from has a lot of additional information. Since it's on another forum, it's not appropriate for me to post the link, but you can google the info yourself and locate it easy enough. Did the dealership you ordered the key from actually program it for your car? It sounds like they may have sent you an unprogrammed key:
EWS is BMW's "Electronische Wegfahrsperre" or Electronic Immobiliser". There were two versions of EWS used on the E34 and E36...
EWS I: 1/94 to 1/95 - Improved on the Drive Away Protection by adding a starter immobilisation circuit.
EWS II: 1/95 to end of production - Improved on EWS I by adding the Key Chip and Transponder to the immobiliser circuit. New ignition keys can be bought from the dealer pre-cut and pre-programmed for £30 plus, depending on the type. You'll need to take the V5 in your name plus some ID. Expect to wait around a week.
Old 09-27-2015, 08:22 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
Thanks, DanL. Thread moved.
Old 11-12-2015, 07:59 AM
laguna30's Avatar
My Ride: multiple E21s, several E28s, a Z3Coupe, a 14 335xi, and a Bavaria B
Have you talked to a locksmith yet?
If the key has not been programmed to the car then you probably need a dealer
A wreckingyard might provide matched keys, locks and ECU
Swapping everything might be an option if everything else fails
It sounds as if you are heavily invested in this vehicle and this hopefully is your final hurdle
Your tone seems as if you have gotten some assistance from someone ( in that you have a key) They might be able to provide the sequence of events to resolve this as well
I would reframe from chopping up the wiring until you have a torch in the other hand and the cars life is measured in minutes
You are developing a strong bond with this 540
It's not all bad...
Old 12-25-2015, 05:33 AM
Mykk's Avatar
My Ride: E34 540i/6
Model Year: 1995
Engine: M60B40
To disable/bypass the EWSII on the E34 540i you replace the 484 DME with a 404 DME (Ebay), cut and leave disconnected the green wire at pin 66 to the DME. Cut and connect together leads 1 & 3 at the EWS module under the dash.
This is also the same procedure to run a performance chip/tune if also interested. Cheers
Ruf930
Lounge
12-17-2009 07:56 PM
sixcard
Lounge
12-17-2009 05:37 AM
Rudy
Lounge
22
10-26-2008 06:07 AM
andy545
Lounge
15
04-10-2006 08:41 AM
IrishEyes
Lounge
10-26-2005 04:03 PM
Quick Reply: Johnny B
