'06 e60 sucessful halogen to oem bi-xenon swap
Old 01-29-2009, 01:18 AM
  #21
Milko75's Avatar
My Ride: 530ix / E60
What you mean green and grey wire together with a common earth? Have the wires get some earth somewhere?
Sorry, maybe stupid question..
Thanks
Old 01-29-2009, 02:28 AM
  #22
Dav530d's Avatar
It's been so long since I did this mod, need that plug diagram which is on this site somewhere then I can explain.
Old 01-29-2009, 04:22 AM
  #23
Milko75's Avatar
I have done wiring this way. I made xenon extra earth to halogen socket and all others inside the headlight.
Is there something maybe wrong?
Old 01-30-2009, 12:49 AM
  #24
Dav530d's Avatar
Mine is similar, I earthed the xenon ballast to the 'extra earth' like on oem, and I didn't wire in the shutter but plan to do this. It looks OK
Old 01-30-2009, 03:50 AM
  #25
Milko75's Avatar
Ok. Thanks the reply. I?ll check my wiring connections and hopefully I can solve problem that way.
Old 02-02-2009, 07:04 PM
  #26
mtrinh1's Avatar
sounds like ur green wire goin to the gray wire might be loose, try checking that, otherwise everything looks good. shouldn't be getting the message.
Old 06-07-2009, 09:47 PM
  #27
s012205's Avatar
Question
Hello
I have 528i 2008 which came with a standard hallogen lights. I retrofit it with bi xenon headlight. I just have one problem with the highbeam as in this model 2008 the outer light work both as low and high beams using the shutter. The bulb (35 watt) inside the inner light is used for the angel eye. So I connected the wire that goes to the high beam in the standard hallogen light directly to the shutter. It works the shutter could open the high beam from the xenon bulb but it gave me an error that the high beam light is malfunction. So I attached Capacitor (4700uf 35 v) to get ride from the message. Now the error message is not there when I siwth the car on but when I push the stack backward to activate the high beam the error message apear again and stay there until I swith the car off. When I push the stack toward me there is no error message. Also while I'm driving the high beam comes on for a second by itself whithout pushing anything. Is there any solution for it??
The xenon light and angel ayes works great without any error message.
Old 06-20-2009, 05:30 PM
  #28
BlaSTiWi's Avatar
I got mine from a complete retrofit kit but I think the p/n for just the plug is 61 13 6 931 864 which look like:
Originally Posted by JMEBBK' post='918431' date='Jun 20 2009, 08:24 PM
Ive been speaking to Dav530d about this
I want to do this mod on my pre-LCI 2005 535d
and write up a DIY if all goes well.
i need LCI lights, xenon bulbs & ballasts and capacitors.
all i need to know is what plugs i need,
and ima start this mod with no experience and no fear!
Old 09-29-2009, 05:35 PM
  #29
medik13's Avatar
mtrinh1, Did you figure out why you were getting the parking light malfunction. I have just completed the retrofit and have the same parking light malfunction.
Any help???
Old 10-26-2009, 05:10 PM
  #30
machy's Avatar
Anyone have any suggestions where to get a retrofit kit to do this? You guys recommend replacing the existing lights with xenon projectors or should i just replace the whole headlight? Found tons of different ballasts and ignitors... any suggestion which works best?
Thanks...
Mike
Quick Reply: '06 e60 sucessful halogen to oem bi-xenon swap
