Upgrade caliper sets for rear axies BMW X5/X6 F15/F16/F85/F86
Old Sep 14, 2018 | 03:40 AM
tro-nik's Avatar
My Ride: 5Series
Model Year: 2018
Default Upgrade caliper sets for rear axies BMW X5/X6 F15/F16/F85/F86
This kit is designed for all owners of M-series X5/X6 F85/F86/E70/E71.
You can upgrade your brakes on rear axies by using this kit:
- 4-pistons Brembo caliper. (we modify it to use 385*24 rotor). The caliper is painted in blue. Also there is a possibility of painting in golden color or other
- caliper adapters for this caliper
- bolts
- brake lines
Brake pads you can buy in your country - we will give an OEM number.
Only you need is replace your rear calipers, rear pads, rear lines with our one. The kit is bolt-on.
The rear brake disc does not change.
Adapters are made of duralumin D16T with anodized oxide coating.
Adapters are supplied with high-strength bolts fastening.
The size or wheels should be 19'' at minimum.
If you have X5/X6 F15/F16/E70/E71 (not M-series), you should to buy our kit and rear rotors 385*24(34 21 2 284 903, 34 21 2 284 904)
If you want to upgrade whole your brakes - use other our kits.
Total price - 1600 USD
tro-nik
Sep 13, 2018 12:36 AM
Blauparts
Dec 10, 2013 12:20 PM
Pitch Black
Jun 23, 2011 11:48 PM
pinguhk
Apr 13, 2011 05:45 PM
kreveta
Oct 18, 2010 11:38 AM
