Upgrade caliper sets for rear axies BMW X5/X6 F15/F16/F85/F86
This kit is designed for all owners of M-series X5/X6 F85/F86/E70/E71.
You can upgrade your brakes on rear axies by using this kit: - 4-pistons Brembo caliper. (we modify it to use 385*24 rotor). The caliper is painted in blue. Also there is a possibility of painting in golden color or other - caliper adapters for this caliper - bolts - brake lines Brake pads you can buy in your country - we will give an OEM number. Only you need is replace your rear calipers, rear pads, rear lines with our one. The kit is bolt-on. The rear brake disc does not change. Adapters are made of duralumin D16T with anodized oxide coating. Adapters are supplied with high-strength bolts fastening. The size or wheels should be 19'' at minimum. If you have X5/X6 F15/F16/E70/E71 (not M-series), you should to buy our kit and rear rotors 385*24(34 21 2 284 903, 34 21 2 284 904) If you want to upgrade whole your brakes - use other our kits. Total price - 1600 USD https://cimg5.ibsrv.net/gimg/5series...09b3c688a7.jpg https://cimg9.ibsrv.net/gimg/5series...3cd2eaf847.jpg https://cimg0.ibsrv.net/gimg/5series...d2b8383d0b.jpg https://cimg2.ibsrv.net/gimg/5series...e73f9c83db.jpg https://cimg1.ibsrv.net/gimg/5series...54602169f6.jpg https://cimg4.ibsrv.net/gimg/5series...7a7f16031b.jpg https://cimg5.ibsrv.net/gimg/5series...ad159ad362.jpg https://cimg3.ibsrv.net/gimg/5series...14b15ed96b.jpg https://cimg6.ibsrv.net/gimg/5series...e0d55c67bd.jpg https://cimg6.ibsrv.net/gimg/5series...1b80d8811d.jpg https://cimg7.ibsrv.net/gimg/5series...5e290b3a44.jpg https://cimg8.ibsrv.net/gimg/5series...104334bf24.jpg |
