Blauparts: 2013 Clearance! $15 Off BMW Transmission Fluid (ATF) Filter Change Kits
![](http://www.blauparts.com/eimages/forum_images/12_13/blauparts_atf_kit.jpg)
$15 Off ALL BMW ATF Kits
BMW automatic transmission fluid should be changed every 30,000 miles - 60,000 miles. The intervals depend on your operating conditions. The BMW automatic transmission fluid and filter should be serviced every 30,000 miles when driving in heavy city traffic, hot weather, trailer pulling, and other severe driving conditions. The 60,000 miles change interval applies to those who mainly put on highway miles. All customers should check their BMW owner's manual and subsequent BMW factory service manual for what ATF is recommended for use in their vehicle.
Some BMW authorities suggest that you don't need to change your BMW's automatic transmission fluid. We simply feel this is illogical. A BMW automatic transmission has hundreds of moving components, such as needle bearings, pressure pumps, clutch packs, servo pistons and seals. These internal components mesh with one another, begin to wear, and create fine metallic particles which contaminate the BMW automatic transmission fluid. Over time, the BMW automatic transmission fluid (ATF) and paper filament transmission filter become contaminated with these particles. If you've ever seen the dark color and particles found in old transmission fluid, you'll agree that it seems very logical that changing the BMW automatic transmission fluid and filter are needed.
Plus Save an EXTRA 10% Off on SELECT Current Sale Items with Coupon Code FINAL13!
$15 Off Select BMW ATF Cases & 10% Off Select 1L Bottles
10% Off All Ravenol of Germany Fluids
$30 Off All BMW Strut and Shock Replacement KITS & an Additional 10% Off with coupon code FINAL13
$15 Off All BMW Strut and Shock SETS & an Additional 10% Off with coupon code FINAL13
Overstock Sale on Select BMW Motor Oils
![](http://www.blauparts.com/eimages/splitted-gray-thin.jpg)
Website:
www.blauparts.com
* Free shipping offers are for FedEx Ground shipping to 48 US contiguous states only. Offers End 1/01/2014
