••ü•• Genesis Angel Eyes Upgrade for LCI Models
http://www.umnitza.com/umnitza-xtec-genesi...e60-p-5679.html
Because of the incredible support we receive from 5-series.net, we are offering 10 people the opportunity to purchase these for $149.99
Tomorrow morning, we will roll out this to all the other forums and the price will be $169.99.
Umnitza introduces the Genesis Angel Eyes for E92 and E60 LCI ICE (Integrated Color Enhancement)
A new product that transforms the factory luminescent ring technology to a more technologically modern look. This product will give you a whiter, brighter, halo output. The BRIGHTEST output, OEM PLUG AND PLAY CONNECTOR UPGRADED ANGEL EYES AVAILABLE. COMPLETELY PLUG AND PLAY with NO ERRORS.
CLASS LEADING FEATURES: (not available on any other competing product)
* Patent-pending Narrow-Tuned Beam System
* Patent-pending Spring-Loaded Fixture Assembly
* Patent-pending Spring Balancing Rod System
* All aluminum body
* Four High output LEDs - 2X More than the nearest competitors
* Highest Output LED - 7W Total
* No Error, No Flash Required
* Voltage Stabilizing Device
* 4-Direction Draw Bar Device
Application (Please consult your owner's manual for your application fitment type):
Applications: All H8 BMW Angel Eyes
E82 All,
E90 09+ LCI
E90 M3 All
E92 All
E93 All
E60 08+
E60 M5 08+
E63 08+
E63 M6 08+
E64 08+
E64 M6 08+
E83 X3 08+
E70 X5 07+
E71 X6 08+
Product Description (may describe some optional equipment):
With the narrow tuned beam angle, this ICE enhancement is capable of guiding the light source directly into the aperture of the original lighting fixture. This direct beam output is stabilized by a spring loaded seating and rod mechanism to maximize throughput using the best in class output 7W LED.
The all aluminum body unit provides exceptional heat dissipation, increased LED lifespan, and most importantly - LESS DECAY. Some LED products look good to start, but they are overdriven by their power sources and eventually the LED loses it's "luster". Not here.
The four high output LEDs are twice the amount of the leading competition, but this does not cause any errors on the dash. Further design was carefully scrutinized by engineers to prevent any radio interference despite the increased number of LEDs. Therefore, you just plug and go, no reflashing the computer is required and the ECU just keeps on working and doesn't void your factory warranty.
* All aluminum body
E82 All,
E90 09+ LCI
E90 M3 All
E92 All
E93 All
E60 08+
E60 M5 08+
E63 08+
E63 M6 08+
E64 08+
E64 M6 08+
E83 X3 08+
E70 X5 07+
E71 X6 08+
Currently, at the $149 price, this is at least $50 less than the nearest competitor that has 2 LED, and over $150 less than the most expensive unit out there.
I'm interested.
How do these compare to the Predator ICE V3 that you were experimenting with recently?
Any comparison pics vs OEM or vs other competitors?
What color temps are available?
What does the install involve since this is more than just a bulb replacement?
Originally Posted by wolfgang0524' post='1036277' date='Oct 19 2009, 08:33 PM
I'm interested.
Comparison on the GP Thunder is attached
6000K is only available and install is just a bulb replacement, nothing more.
Thanks for all the orders.
Looks like our system allowed a few more than the 10, so we've stabilized the price for now to $169.99.
Thanks - we hope to see these installed soon
The first units should be arriving in a few days.
If you could email us photos of the installation during the day and dusk, we'll post them up.
socale39
09-05-2023 08:30 AM
Tsoup
15
12-20-2021 11:14 AM
rizwan1377
04-05-2015 05:22 PM
