transmission fluid change
My Ride: 2006 525i with nav and blue tooth , the wifes
and 1999 740il, my beast
Previously I read (I think here) that the transmission does not have a drain plug. Not so! The transmission PAN is replaceable and comes with drain plug, gasket and o-ring
Bavarian Autosport sells em for $242, Partsgeek for $165 Drain fluid, unbolt pan, insert new 0-ring, bolt up pan and refill by pumping through fill hole in side of transmission.(BavAuto part #is 24117536387, Partsgeek W0133-1847360)
Valvoline Max-Life transmission oil meets the BMW specs for my 1999 740il and so I plan to use this fluid for this application also. I change fluid every 60k miles.
If there is a DIY on this site on this please tell me where to find it. I also am trying to figure out how to post pictures....as I am happy to provide some DIY help when I start my projects.
I have NO affiliation with the companies mentioned...
HenryB
HenryB
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
HenryB
HenryB
And i think we use the ZF oil and not the valvoline, make sure you get the correct oil otherwise it will
damage your gearbox
There's a DIY somewhere on here, I'll try to find it. Personally I'm waiting on the Bentley manual to come hopefully very soon (I've got it pre-ordered) to read up on it before doing it myself. I do know there is a temp requirement for the level reading on the fluid.
The fluid spec for the GA6HP19Z (2006 525i) is LT71141 and the Valvoline Maxlife Spec meets this....says so on the bottle.....so I have been using the MUCH less expensive Valvoline Maxlife in my 740il for 50K miles now with no problems....plan to put it in my 525i also.
Look at this site and see the Transmission spec for the E60. Note that this actually states change at 100,000 miles
http://admin.webmakerx.net/images/Si.../autotrans.pdf
Better read that chart again! For GA6HP19Z the fluid isn't Esso's LT71141 it's Shell M-1375.4.
My Ride: 545i, Adaptive Xenons, 19" 166's
Only fluid I've used in my E60 came directly from the BMW dealer, which is ESSO right? I wouldn't put anything else in the tranny.
My Ride: 2007 550i Titanium Grey Metallic - 6 Speed Manual, Sport Suspension, Premium, Cold Weather, Navigation, Shades, L7 Sound
got my appointment too for the transmission June 9th inclusive a differential change as well...
