Opening headlight
Old 05-27-2010, 03:26 AM
johal's Avatar
People, i have had 3 attempts on opening my headlights and its just not happening for me. Ive tried heating the seal with a heat gun, seperating it with screwdrivers, soldering it appart but nothing!! I think i've cut into my hands more then the actual headlight lol. Can't seem to find any threads on this either.
Someone please give me some advice, i need this done asap.........
Old 05-27-2010, 10:31 AM
protams's Avatar
My Ride: 530iA 04
For F10?
Old 05-27-2010, 11:08 AM
Rizbel's Avatar
My Ride: 545i Sport
If it's for E60 headlights, see links below. GL.
Use a Dremel Multimax tool or equivalent.
Just follow the cutting lines as per Umnitza Install PDF.
Old 05-27-2010, 12:48 PM
Rizbel's Avatar
My Ride: 545i Sport
Or the Fein MultiMaster Oscillating Tool, but it's too expensive.
Old 05-27-2010, 02:45 PM
umnitza's Avatar
My Ride: M5
Originally Posted by Rizbel
Old 05-28-2010, 03:50 AM
johal's Avatar
Thank's for the links guys, but they don't sell that type of tool in th U.K, i've looked everywhere. Can i use a dremel instead? Also have you guys actually cut into the seal or cut along the seal straight into the plastic lense cover?
Old 05-28-2010, 04:24 AM
johal's Avatar
actually i've just found this tool....is this one ok?
Amazon Amazon
Old 05-28-2010, 04:35 AM
johal's Avatar
Originally Posted by protams
For F10?
E60
Old 05-28-2010, 06:10 AM
umnitza's Avatar
My Ride: M5
use a soldering iron with a flat spade end, it would be your best setup, not messy and easily closed after completion.
Old 05-28-2010, 10:54 AM
Rizbel's Avatar
My Ride: 545i Sport
Only if you like to inhale burnt plastic fumes. Wear a respirator. An oscillating tool is surprisingly clean to use with plastic materials.
I'm sure others in the forum that have done this mod will agree with me on this.
Quick Reply: Opening headlight
