Intake grate removed
When I initially installed my RPI air scoop, I saw this inlet grate:
Probably safe to assume it prevents large-ish objects from finding their way into the air box. Ended up cutting it out then deburring the edges around the inlet. My camera pooped out before I could take a photo of the finished product, but here are a couple pieces of the grate that was yanked out:
Now I get to clean my air box of large foreign material more often- yay!
So why would you do this "mod" again? Its proven to add like 10HP at the wheels or smth?
Props on RPI scoop though
(I got a scoop too and it really does work!)
Not sure what good it will do.
My Ride: check siggg
I guess the grate could potentially produce turbulence which could lessen HP...but I don't really think it's noticeable AT ALL. It is interesting what you find in air intakes though...I've found Styrofoam, cigarette butts, and an assortment of various leaves.
IIRC, RPIpower/eloy commented on this in another thread and stated no difference with or without that grate...
***edit: found the thread: http://forums.5serie...__1#entry927938 see post #3
***to the "old timer's", check who the author of that thread is
Then Eloy probably also feels the same about the Dinan Throttle Body which effectively does the same thing:
Regardless of the function, the size of the hole still represents a restriction of intake air-flow, making the larger bore of the Dinan high flow versions enable the engine to breathe better for more horsepower and torque, most effetively in wide-open throttle scenarios.
from the thread I linked above (RPIpower = eloy)
feel free to contact Eloy/RPI directly, I would love to see your dyno's tho
