xi staggered wheels?
Old 05-07-2010, 06:31 PM
harlem's Avatar
My Ride: 2006 bmw 530xi
hello can u put staggered set of rims on a xi model?
Old 05-07-2010, 07:38 PM
-Mike-'s Avatar
My Ride: 2008 550i sport
plz look at my gallery
Old 05-07-2010, 07:53 PM
C's Bimmer's Avatar
check out your other thread and my reply. yes, you can. i was one of the first to do it. check out my gallery and go back to my old pix for my 530xi with 19" staggered.
Old 05-08-2010, 06:50 AM
harlem's Avatar
thanxs bro.appreciate that
Old 05-09-2010, 11:31 AM
corey's Avatar
My Ride: Car
BMW offers staggered 124's with high offsets specifically for xi models as an upgrade option.
Old 05-12-2010, 05:32 AM
localmoition1717's Avatar
I just purchased a 528xi the other day. Whats the max width on the front and back you can go? Thanks
Old 05-12-2010, 05:59 AM
BlaSTiWi's Avatar
Kinda broad question that depend on various things... the offset, tire size & the wheel diameter to name a few ... i.e. w/ 19" width of 8.5" - 9" up front w/ ET35-38 can do while on the rear width of 9.5"-10" w/ ET33-35 will fit ... will probably able to fit wider w/ 18" and maybe less w/ taller 20" depending on the offset & tire width ... and if you go w/ custom fitment you can dial everything to the max they way you want it.
When you use aftermarket suspension like coilovers all will change again since it gives more clearance inside to use wider wheel w/ higher offset.
Old 05-12-2010, 10:11 AM
corey's Avatar
My Ride: Car
Not sure of max, but factory tires on staggered OEM wheels are f-245 and r-275.
Old 05-12-2010, 10:51 PM
Thanks for the help. I'm looking at the 20" MOZ Calgary wheels
Old 05-12-2010, 11:35 PM
safetywork's Avatar
My Ride: 2008 550i Sport (6-speed)
Forgive my ignorance but I thought the xi were AWD models equipped with transfer cases. If this is true then wouldn't staggered tires abnormally stress out the gearing in the transfer case?
Quick Reply: xi staggered wheels?
