Daylight Autodetect Sensor
Old Apr 10, 2010 | 06:20 AM
ddlrk's Avatar
My Ride: BMW 545i 6 Speed Silver Gray w/ Black leather M5 Sport package
I have my headlight setting switch set to "A" (dial knob turned all the way to the left -little green light on)to autodetect day or night in order to automatically turn on or off my headlights. It was working fine then it got a thorough detailing -wash. After that lights just stayed on no matter day or night while in "A" mode. The lights do turn off and on manually and all other settings work-fog light mode, etc. If I go back into "A" mode the headlights still come on.
Can someone tell me where the sensor is for this and what I need to check? Fuses, sensor, maybe I'm just doing something wrong in the "A" position switch? Is there prehaps a reset? Thanks.
Old Apr 10, 2010 | 01:18 PM
azstar's Avatar
Are you sure you the DRL setting in iDrive isn't switched on?
Old Apr 10, 2010 | 03:13 PM
ddlrk's Avatar
DRL setting?
Old Apr 10, 2010 | 03:29 PM
Sanj's Avatar
DRL=Daytime running light's,which should be a setting to turn off via the i-drive menu.
Old Apr 10, 2010 | 05:24 PM
SilberGrauE60's Avatar
To my knowledge, the 545i does not have a daytime running lights (DRL) setting. So, I believe your problem stems from the detail job doing something to the sensor making the system believe it is dark enough to turn on the lights. Unfortunately, I cannot help you locate the sensor in question. Hopefully someone else knows the location.
Old Apr 10, 2010 | 05:42 PM
joebaggg's Avatar
My Ride: 2013 535i xDrive AW/Black M-kit
take it for a car was that always fixes mine haha
Old Apr 11, 2010 | 04:16 AM
ddlrk's Avatar
Day Time Running lights are running fine so I'm not sure what setting DTR would have to do with getting the "Autodetect" day/night feature running.
The other gentlement is correct, the 04 545i does not have the DTR light settings in iDrive. I had to have that set at the shop. My DTR lights run fine.
I think the sensor is bad, in "auto" mode the car thinks its dark all the time thereby turning on my lights. I need to find this sensor or something else that could be related. Any ideas are welcome. Thanks so far.
Old Apr 11, 2010 | 09:05 AM
ddlrk's Avatar
FYI: Found the day light sensor. It is on the inside of the car - Center of front dash toward windshield, little black knob. Some might mistake it for alarm but we all know that's on the mirror.
Anywho...fixed it.
Old Apr 16, 2010 | 05:37 AM
Rudy's Avatar
Anywho...fixed it.
That's actually the solar position sensor, not the ambient light sensor.
Take a look at the following threads, if you haven't seen them already:
https://5series.net/forums/topic/866...uto-headlights
https://5series.net/forums/topic/269...ensor-is-crazy
https://5series.net/forums/topic/195...adlight-sensor
Old Apr 16, 2010 | 06:12 AM
ddlrk's Avatar
Thanks for the correction and links. After reading through all three I think I'm just screwed. I have the latest software, etc. and I still have the issues many have described. Just sux because I love my car.
I am going to try some of the setting tricks I read. Only because it was working fine until I lost battery. Not sure how this would affect the daylight sensor settings but perhaps.
