Valve cover Gasket - 545i
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
Hi,
I am in the process of replacing valve cover gasket on my 2005 545i.
Do you know how to reposition valvetronic motors (the servomotor for the eccentric shaft)? TIS says that you need connect the diagnostic tester and do the adjustment, because there is a risk of damage the intermediate shaft.
Any ideas?
Any ideas?
Are you replacing this because you have a leak? If so, I went through numerous changes, even replaced the valve cover because they later thought that it was warped. It wasn't the valve cover...it turned out to be a leak in the #1 Sparkplug that was causing the leak. Evedently, there was a casting issue with the cylinder head and so it was replaced. $9000 later no problem, btw the car was out of warranty but was still covered. Great service writer/manager at Roseville BMW here in the Sacramento area for fighting for me! Good luck to you otherwise.
All I would do at this point is panic.
That looks like major surgery.
![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
My Ride: 2005 545i Sport 6MT
Interesting. I was planning on doing both soon, but saw no procedure on alldata that said you needed to reprogram the servo motor. I was under the impression of bolt and go..
Where did you see the bulletin that said that? Do you mind posting it or a link?
http://www.bmwtis.com/
http://www.m5board.com/vbulletin/m5-...on-online.html
Hope that will help. I have more pix from this project. If you need help\advice please let me know.
How many miles you have on your car?
I have a printout from TIS. My scanner is dead right now, but you can buy access for 24h or try to find the BMW TIS CD on eBay.
I am an ASE certified master tech, but am i fairly new to this particular engine. I dont see why it would need reprogramming, unless you changed the levers. It is only an actuator that is PWM i believe. I would think it would be based on the position of the eccentric shaft how the computer controls, not the other way around.
Let me know for sure if you find out if they need reprogramming. I may call the dealer and ask.
