DIY LCI tail light retrofit (cheaper method) Verison II
Old Oct 26, 2009 | 07:29 PM
ricky1329's Avatar
My Ride: 530i Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
I like the LCI LED rod DIY LCI tail light retrofit (cheaper method) Verison II-images.jpg but hate the original LCI design about brake light on.DIY LCI tail light retrofit (cheaper method) Verison II-images1.jpg
Follow the folk from Version I suggestion about the turn signal strobing
https://5series.net/forums/index.php?showtopic=83675
Compile the partial about the turn signal (reduce strobing) from the schematic for pre-facelift e60 from MJA
https://5series.net/forums/index.php?showtopic=86144
And change the brake light to LED rod and Fog light (by two diode) together. (circuit broad attach to cable)
Turn off the light and press the brake. RESULT - Third brake light; LED rod and FOG light on at the same time.
Turn on the light. RESULT - LED rod and FOG light on (but in 3.6V instead of 12V)
Turn on the light and press the brake. RESULT - Third brake light; LED rod and FOG light on at the same time. (all at 12v)
Old Oct 26, 2009 | 07:37 PM
pinguhk's Avatar
My Ride: Mini Cooper
congrate looks good.
How much did it cost for the parts?
Old Oct 26, 2009 | 09:46 PM
ricky1329's Avatar
Euro Spec Tail light $435 https://5series.net/forums/index.php?showtopic=84664
OEM cable and DIY circuit must less than ?250 GBP
Old Oct 26, 2009 | 10:06 PM
etchu's Avatar
wow great mod man.
Old Oct 26, 2009 | 11:01 PM
pinguhk's Avatar
what I mean is your DIY.
Old Oct 27, 2009 | 07:27 AM
ricky1329's Avatar
cheaper than ?250 GBP a lot
Old Oct 27, 2009 | 07:48 AM
mrfva's Avatar
My Ride: .
Model Year: .
Nice job Ricky
Old Oct 27, 2009 | 12:55 PM
mja's Avatar
mja
My Ride: Had: 530D 170kW Black 6MT
It's not 3.6V, it's a chopped 12V, meaning that you have approximately 1/4 th of the cycle (which is about 12-13 ms in total) 12V and 3/4 cycle 0V. There's a (huge) difference.
Old Oct 27, 2009 | 05:56 PM
ricky1329's Avatar
I known but just want simple describe to others whose haven't electronic background.
Old Oct 28, 2009 | 06:28 AM
ricky1329's Avatar
Originally Posted by mrfva' post='1041309' date='Oct 27 2009, 11:48 PM
Nice job Ricky
Wish this version no strobing on the Turn lights anymore. Wish this time no folks say brake signal too dim
