Homemade LED taillight adapter
Old Dec 26, 2008 | 04:22 AM
BenAnd's Avatar
My Ride: BMW e60 525IA 12/2003
Hi
On request from GENEaTALS , here a littel DIY , for the people that want to fit Org. BMW LED number plate tailligth's and don't have the opportunity of getting the adapter from BruceMiranda ( shiping cost to Europ cost more than the adapter's themself ).
There should be no doubt that Bruce deliver them more professional done , so I hope no hard feeling's becourse of my littel DIY Bruce
You will need :
2 x LED number plate taillights BMW Part no. : 63 27 7 193 293 / 15-20 USD/ a pice
2 x 24Volt/2Watt bulb's 2-3 USD/ a pice
4 x Female wire Pin's , BMW part no. : 61 13 1383 776 / 1-2 USD for 4 pice
4 x Male wire Pin's , BMW part no. : 61 13 1376 191 / 1-2 USD for 4 pice
2 x 20 cm wire in 2 different color's
10 cm ?10 heat flex
20cm ?5mm heat flex
Now follow the pitcure's ( you have to make 2 adapter's , one for each number plate tallight )
Old Dec 26, 2008 | 08:40 AM
lightfytr's Avatar
My Ride: 2007 530i Alpine White with Navi and Premium PackageIn progress: OEM Mtech kit, H&R Sport Springs, and 19
Ben you are the man. With posts like these we will continue to grow as a strong e60 resource. Thanks to all of you guys that do this type of grunt work...
Old Dec 26, 2008 | 08:43 AM
flyingpuck's Avatar
WOW! What a great DIY, thanks BenAnd!
Old Dec 26, 2008 | 09:03 AM
mikeg3tsguap's Avatar
im not the do it yourself guy but that looks darn easy thanks ben
Old Dec 26, 2008 | 10:14 AM
Gene's Avatar
excellent write up ben...thanx for sharing
Old Dec 26, 2008 | 10:40 AM
zte's Avatar
zte
My Ride: 530d M-tech -06
Thanks ! Great DIY
Old Dec 26, 2008 | 01:05 PM
schulrog's Avatar
very good! won't the bulb melt the electrical tape?
Old Dec 27, 2008 | 01:32 AM
BenAnd's Avatar
Hi
No it won't melt the heat flex , the bulb's that is 24Volt2Watt don't get warm becourse of the low Amp thy use , temp aprx. 25 Degrees/50 Farenheit
Regards
Ben
Old Dec 27, 2008 | 01:54 AM
Bteljuice's Avatar
the whole thing will cost at around 35-40$?
Old Dec 27, 2008 | 06:55 AM
AlexFW's Avatar
He is the man, but not (only) for this DIY
