center channel speaker grill removal
Fingernails
in the corners. Screwdriver make scratches.
Edit: pulling the sensor won?t work realy. But you might get an open corner for a beginning. If you pull for the first time, the clips are clipsing hard
You also could remove the Monitor by 2 Torxx and remove the grill from below.
in the corners. Screwdriver make scratches.Edit: pulling the sensor won?t work realy. But you might get an open corner for a beginning. If you pull for the first time, the clips are clipsing hard
Give this a look and see if it gives you a better idea of what to do...
RA__Removing_and_installing_speaker_frame_on_panel_for_instrument_panel_at_top.pdf
Thanks guys.
Rudy, your the man. I've downloaded tons of instructions (as provided by you) from various threads so I can figure out how I'm going to do the custom stereo thing.
Just had not seen this one and did not want to break any clips or scratch the grill edge. The grill is off. I have the special tool. Found it cleaning out a kitchen drawer a few years ago. Took my neighbor to tell me it was a cake server. So it went straight to the garage. That and the teeth picking/scraping tool the hygenist uses to clean your teeth are my 2 favorite stereo install tools.
But this leads to another question. I know Morel makes a good 4" driver that will pop in there. And the Scanspeak might. But does anyone know what is around the "cup" the speaker drops into? My thought is to cut out the cup and mount a small baffle from the top to mount a slightly larger speaker and/or slip in a small tweeter next to the mid.
Cheers!
Bob
PS Rudy, I see you all over this place. If I had to guess, BMW mechanic? Or engineer? Definitely MVP. Thanks again.
Cheers!
Bob
incoherent
Apr 15, 2015 04:48 PM
