Leak around Steering Fluid Reservoir
Old Jan 12, 2012 | 11:23 AM
balbs's Avatar
My Ride: BMW
I was cleaning around the engine compartment over the weekend when I noticed some leaks around the steering fluid reservoir. Is it coming from the hole on the cap? Notice there are also some around the left hose clamp area at the bottom of it. Is this something to worry about? At this time I wiped it up and will keep an eye on it.
Old Jan 12, 2012 | 11:49 AM
luigi524td's Avatar
Attachment 129641
Probably not dangerous - just annoying. Try to tighten the hose clamps and ensure the cap is properly screwed down. Really easy to cross thread or crack plastic parts. Check the o-ring in the cap to see if it's deteriorated. That's an easy fix.
Old Jan 12, 2012 | 11:54 AM
balbs's Avatar
My Ride: BMW
Thanks. In retrospect. I had the car serviced last september with the 60K miles inspection. The tech probably topped off the fluids and may have over-filled the steering fluid. I'll check on it tonight to confirm.
Old Jan 12, 2012 | 01:09 PM
Maher's Avatar
Guys, I tend to get the same on my 520d 2008 every now and then. Not sure if it's a common issue with all E60.
Old Jan 12, 2012 | 02:08 PM
pcy's Avatar
pcy
that looks more like someone spilled while topping off the fluid.
whoever spilled, should've wiped it off...
Old Jan 12, 2012 | 03:25 PM
syrousd's Avatar
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
You need to make sure the seals in the cap are not busted. I would clean the area throughly and every week check to see if it is wet again. If I recall correctly the cap is 25 dollars "New" or 5 bucks at the junk yard.
Old Jan 12, 2012 | 03:27 PM
balbs's Avatar
My Ride: BMW
Yeah, it looks like it probably came from the cap and started pooling around the edge ring and then down the hose. Bonehead me didn't even think to check the cap nor fluid level while I was looking at it.
Old Jan 12, 2012 | 03:45 PM
syrousd's Avatar
I know how you feel brother,it happens to me all the time!
Old Jan 12, 2012 | 04:31 PM
toyota2bmw's Avatar
There's a gasket on the cap that may need replacing. Or it may be a hairline crack in the reservoir that only exhibits leaks under pressure.
Old Jan 13, 2012 | 06:41 AM
covinsky's Avatar
My Ride: 2006 White 530xi
Each of the four BMW's I have owned have done this. I believe it was designed with a pressure relief, so a small amount of fluid at top, near the cap is normal. Tightening the clamps on the hoses at the bottom has been done to limit seeping, but replacement has never been recommended. Chris
