Cooling System Flush, refill, and venting system
My Ride: 545i Sport
I just put a new thermostat in my 545i (N62) and it was easier than the 330i(N52). Access is easy with only a nut and three screws, a cable, and a hose to remove.
Pictures to follow with step-by-step procedure.
My Ride: 545i Sport
![Cooling System Flush, refill, and venting system-2011_0616_182947.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/122397d1482366532t-cooling-system-flush-refill-venting-system-2011_0616_182947.jpg)
Raise car on jack stands safely. Use proper tools designed for the job.
![](https://5series.net/forums/uploads/1256215400/med_gallery_25725_2452_344379.jpg)
Remove splash shield. (968TurboS photo)
![Cooling System Flush, refill, and venting system-2011_0618_124455.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/122396d1482366532t-cooling-system-flush-refill-venting-system-2011_0618_124455.jpg)
Draining coolant
Allow engine and coolant to cool before proceeding.
Remove cap from the expansion tank and place pail under radiator, then loosen petcock (red) to drain coolant.
Remove reinforcement plate and remove engine block drain plug from left side of engine and drain coolant.
Properly dispose of drained coolant.
Adding Fresh coolant
![Cooling System Flush, refill, and venting system-2010_0306_143702aa.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/122399d1482366532t-cooling-system-flush-refill-venting-system-2010_0306_143702aa.jpg)
(50% BMW antifreeze and 50% distilled water, 15 US qt) and venting system at the same time.
-Switch ignition ON without starting engine.
-Set blower fan to low and temperature for driver and passenger side to full warm. Set seat heat to MAX if available.
-Fill expansion tank slowly until Max level.
-Leave cap open and run engine at idle for 1 minute.
-Adjust level to MAX and close cap.
-Run engine to operating temperature.
-Shutdown engine and after engine has cooled, recheck coolant level.
** Disclaimer**
I hold no responsibility for any damage or injury occurred from following this DIY. Proceed at your own risk.
Next: Expansion Tank removal and installation
My Ride: 545i Sport
-Drain coolant (see post #1)
![Cooling System Flush, refill, and venting system-2011_0618_124338.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/122398d1482366532t-cooling-system-flush-refill-venting-system-2011_0618_124338.jpg)
-Remove hoses (yellow arrows)
-Remove 2 hex screws (red arrows)
-Lift expansion tank to release cable connector (green) to coolant level switch.
Make sure rubber grommet is present and securely mounted.
-Installation is reverse of removal. Ensure pin at the bottom fits securely into the grommet.
Fill and vent system (see post #1)
Next Thermostat removal and installation.
When I replaced my water pump and thermostat, I didn't think about draining the expansion tank. I only drained the coolant from radiator through the plug and of course all the fluid from the hoses leading into the pump. Following the advices of some members here, I also flushed the system with water and let it fully drained over night since I was getting dark.
never mind, I just realized I did use a hose to flush the expansion tank so unless something else goes wrong with the system, hope not, I don't see the need to remove the tank now.
Great job Riz. Looking forward to any other DIY you're planning to do.
My Ride: 545i Sport
I forgot to mention the reason why I needed to get a new coolant expansion tank. The brown plastic floating stick has become brittle and broke from its base.
I fear that the pieces might get inside the engine block and mess things up.
My Ride: 545i Sport
Actually I did a mod while the car is up on jack stands and front bumper off. Since the halogen lamps are now disabled via NCSExpert coding (no DRL and switched Flash-to-pass to the xenon lamps)
and I don't have fogs mounted (genuine M5 front bumper has no fog lights), I rewired the halogen lamps to come on when the fogs are switched on. Just don't tell Iceman
![Cooling System Flush, refill, and venting system-2011_0618_184004.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/122400d1482366532t-cooling-system-flush-refill-venting-system-2011_0618_184004.jpg)
![Whistling](https://5series.net/forums/images/smilies/imported/whistling.gif)
BTW, do you happen to know where I can find the DIY on how to remove the front bumper? I assume I can remove it from searching for the screws but after Turboawd mentioned about how the active stabilization module was located behind the wheel weld, I have to make sure before removing the bumper. Was thinking of ordering the front bumper and have it shipped, painted instead of paying the local excessive charges.
