Who makes the auto transmission, ZF, Getrag, General Motors?
on
My Ride: 2009 535i X Drive (current)
2008 335Xi Coupe (retired)
2005 X3
![Default](https://5series.net/forums/images/icons/icon1.gif)
I'm new to the E60 having just purchased a CPO'd 2009 535i X Drive w/ 24K miles 2 weeks ago. I don't know about the E60 transmission wise but I know on the E90 3's, the 328 uses a GM transmission & the 335 uses a ZF, one of the additional reasons (besides the N54 motor) that I went with the 335 over the 328. I'm not going to spend $50K on a BMW and get a GM transmission if I can help it.
jkz
jkz
on
My Ride: 2008 550i (E60) - Titanium Silver | Black Dakota w/ Bamboo Anthracite | Sports Package | Premium Package | Steptronic | Navigation | Logic 7
Former:
1995 540i MSport (E34) - 6sp, B&M Short Shift | Dinan Intake | Dinan Exhaust | Dinan Chip
1987 325iC (E30) - sold
Interesting to note from wikipedia, "the ZF 6HP26 itself is rated for a maximum input torque of 600 newton metres (443 ft·lbf)".
on
My Ride: 07 E61 530d M-Sport.
BMW use various different versions in their cars. I know you don't the diesels over there but they are the ones I can compare. The 530d and 535d have transmissions rated up to 600nm, the lower diesel engines (525d and 520d) get a transmission rated to 400nm. I would imagine the V8s would get the heavier transmission and the 6 cylinder petrols the 400nm one but I don't know that for sure.
on
1 Post
My Ride: 2004 E61 530D - Dynamic Drive - Active Front Steering Sport Seats - Voice Control - Head Up Display - Nav Pro - Bluetooth - Panoramic roof - Front/rear heated seats
Bimmerfest:
- GA6HP19Z (designed for maximum torque of 400 Nm)
- GA6HP19Z TU (designed for maximum torque of 400 Nm)
- GA6HP26Z (designed for maximum torque of 600 Nm)
- GA6HP26Z TU (designed for maximum torque of 650 Nm)
- GA6HP32Z (designed for maximum torque of 750 Nm)
on
They are max the transmissions are designed for and not all are built to the max spec. The 6hp26z in the 520/525d is only rated for 400nm.
on
I really don't know TBH. I only know the box is rated lower because alot or remapers warn of going to high on those cars. It's been discussed on UK forums a fair bit but I've never seen anything to show the actual differences.
on
My Ride: 545i sport
Like has been said, BMW has used a mixture of ZF and GM transmissions in several BMW models. Most notably, the 3 series. My '99 E46 ( B25TU) had a GM transmission and my '00 E46 (B25TU) came with a ZF transmission. Generally, the GM transmissions have a higher torque rating than the ZF and are considered a little more durable. However, the concensus seems to be that the ZF boxes exhibit a better shift quality. Recently, BMW has slashed the quantities of transmissions purchased from GM (GM boxes are made in France).
