mtech front bumper retrofit question
My Ride: 06' BMW 530xi
I just bought the mtech front bumper cover ... can i use the parts from my stock bumper or do i need to buy seperate parts for the retrofit? thanks for your help
Is it a factory oem Mttech bumper or is it a replica Mtech bumper? A lot of the aftermarket bumpers come with the needed parts and then you modify the rest of your parts to fit. With the factory bumper there are several parts that are made just to fit the factory Mtech bumper, some of which you can modify the stock parts to fit.
My Ride: Bmw 530d 2004
Maybe the installation instructions could help you out along the RealOEM:
- MTech Installation Instructions
- www.realoem.com
- www.realoem.com
anazafin that mtech pfd looks technical. thats not the same for say installing a trinity or umnitza bumper? i assumed it was just str8 unbolt rebolt for those replicas?
- Antti -
Oops, sorry. My RealOEM link was bad.
You'll need pretty much everything from "1. Front bumper trim parts list" for a complete install, except the license plate holder and dummy plugs (if you have the headlight washing system).
I meant to post this link for the RealOEM. You can check the part numbers there.
And from the "2. Side member and air guide trims parts list" you'll need parts AT -> AZ. Part numbers for those parts for your car you can check here.
There's not much you can use from your standard bumper.
- Antti -
- Antti -
My Ride: 2008 535i:
1992 Camaro RS:
The replica mtech bumper has a one piece grille. If you have NV or ACC you will have to modify the grille to fit these components - from the close-up pics I've seen it appears a bit risky. Also, the replica mtech bumper does not have the slots for the side reflectors (on LCI cars).
