removing the back seat to get access to the boot
Old Dec 17, 2010 | 12:04 PM
arash's Avatar
hi guys
the trunk lock on my bmw e60 doesnt work.
i cant open the boot manualy anymore i think the cable is broken.
i dont know how to remove the back seats so i can get access to the boot.
help plz
Old Dec 17, 2010 | 12:11 PM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Welcome to the forums.
I'm assuming you don't have the fold down option. Do you have the ski port in the middle?
The thing is that you can't remove the backseat (backrest) from the cabin, without getting at least your arm into the trunk.
The seat part is easy to remove, just lift hard the front edge. You can open the two bolts in the middle of the lower edge of the backrest, but there are two clips in a trunk that release the upper edge.
- Antti -
Old Dec 17, 2010 | 12:38 PM
arash's Avatar
thanks for reply
i barely can get my hand through but i cant find any key or such.
do u know where is th release key
thanks
Old Dec 17, 2010 | 12:40 PM
Anzafin's Avatar
You're getting through the ski port?
There are two tiny clips in the "roof" just behind the backrest. I try to find a pic or something for you.
Old Dec 17, 2010 | 12:43 PM
arash's Avatar
the cover where the speakers are .
i kind of push the hard and is very tiny space.
thanks
Old Dec 17, 2010 | 12:53 PM
Anzafin's Avatar
Ok, if you're reaching through this hole, you won't make it. Your hand goes between the rear shelf and the "roof" of the trunk and you have to get into the actual trunk.
In this pic you can see the tiny clips. They are tricky, because it's not the little clip you have to move, but you have to put a screwdriver or something into the hole and push against the spring. Sorry I don't remember which direction that is, but you would feel the resistant of the spring. Only problem here is that probably you can not reach these things now...
- Antti -
Old Dec 17, 2010 | 01:06 PM
arash's Avatar
Thanks so much for ur help mate
Its very helpful pictures and I should try it Tom.
I have another problem as well.
The system keeps coming up with the warning message that the right number plate failure.
I have replaced the bulb but the light wont work and the message still showing up.
What could be the possible reasons?
Appreciate your time and help
Old Dec 17, 2010 | 01:11 PM
Anzafin's Avatar
Possibly a broken wire or a bad contact...
Try measuring the voltage from the plug that is connected to the number plate light housing.
Old Dec 17, 2010 | 01:14 PM
arash's Avatar
I think no current flowing at all and i couldn?t find any specific fuse for that.
Old Dec 17, 2010 | 06:51 PM
Rudy's Avatar
Do only US cars have the little "carjacked" handle you pull if you're locked inside? If your car has one of those, just reach through the ski pass-through and grab it with something...
