error code DPF
hello. my name is peter. i`m new to this forum. i hope some one can help me here. i have a 535D year 2005. i have a error code on my engine. it`s "code 4166 - DPF flow resistance too low" something with the particle filter. does someone have a idea what could be wrong. thanks peter
My Ride: Bmw 530d 2004
It seems like your DPF is clogged. It has happened to me also.
Read this thread, I think it will give you some answers! Please ask if you need to know more.
- Antti -
Welcome to the forums Peter.
- Antti -
- Antti -
Yes, it works fine.
Washing the DPF is the least expensive method to start with, so if possible, I think you should try that.
If you don't have any other symptoms yet (than the error message), I think it's not so badly clogged, yet.
- Antti -
- Antti -
