Car won't start!
Old 10-28-2010, 10:19 AM
selbycy's Avatar
Hi guys,
Yesterday my car was starting as normal.
Today I tried to start it and it wouldn't start.
The yellow light was on the dashboard infro screen, is it the battery light?
I could hear the starter motor whirring but couldn't hear any kind of ignition trying to start the engine?
All my lights seem to be working as well?
I tried to jump start it, I left the other car hooked up for 10 minutes before trying to start it but stil nothing happened.
Any ideas would be greatly appreciated.
Regards
Old 10-28-2010, 11:13 AM
jmsod's Avatar
With all due respect, why don't you just call your SA?
Old 10-28-2010, 11:24 AM
selbycy's Avatar
It was 8:40PM and I had to be in work at 9PM, I will call someone in the morning if I can, doing a 12 hour shift now so I'll need to sleep in the day.
Old 10-28-2010, 11:41 AM
kane1111's Avatar
My Ride: Navy 550I
Sounds more or less like the battery!!!!
Old 10-28-2010, 11:50 AM
turboawd's Avatar
My Ride: 2006 BMW 550i
you heard the starter whirring, but did you hear the engine turning also? if not, then you have a bad starter. the starter has a solenoid which kicks the gear out and engages the flywheel. if the solenoid fails, the starter spins, but doesnt turn the engine.
Old 10-28-2010, 11:53 AM
selbycy's Avatar
I could hear a whirring sound, like somthing spinning when I turn the key, but I couldnt hear like an igniter sound or clicking sound of anything 'engaging'
Old 10-28-2010, 12:19 PM
turboawd's Avatar
well, have someone look at the engine while you turn the key. if the pulleys and belt turns, then the starter is ok, if not, bad starter.
Old 10-28-2010, 12:27 PM
selbycy's Avatar
Will do that tomorrow when I finish work, thanks for your help. Much appreciated!
Old 11-02-2010, 11:52 AM
selbycy's Avatar
Just to close the thread, the starter motor was the problem.
Thanks for the assistance.
Old 11-02-2010, 11:59 AM
v_therussian's Avatar
Glad you found the culprit, Tom
Also, maybe a good time to have someone test output voltages on the battery and alternator - just in case
Quick Reply: Car won't start!
