E60 "high battery discharge"
Old Aug 13, 2010 | 12:38 AM
JetSet's Avatar
My Ride: 2006 BMW 525XI
Hi guys i have a 2006 525xi and i have been getting an error message on the main nav screen saying "high battery discharge" i took it to my mechanic they tested the alternator and said its charging the battery fine it must me the battery i bought a new battery and 2 days later the same message what can i be i need some help ....
Old Aug 13, 2010 | 01:16 AM
jasperxli's Avatar
My Ride: check siggg
mine does this too! except mine says increased battery discharge. and everytime this happens i have to reset the time and date... can anybody help shed some light on this subject?
Old Aug 13, 2010 | 03:49 AM
Dandle's Avatar
My Ride: 07 E61 530d M-Sport.
I had an "increased battery discharge while stationary" message a while ago on my car. It was because one of the cars modules wasn't shutting down correctly and still draining the battery when the car was locked. BMW first changed the body control module and that didn't fix it, then they replaced the module in the rear tailgate and that cured the problem.
Old Aug 13, 2010 | 04:20 AM
Luxurytax's Avatar
My Ride: 08 528I Sport/Prem
Try setting your headlight switch to the 0 position each time you leave the car. I'm not sure if hat helps any, but when my car was acting funny with that message, it was a temp cure.
Old Aug 13, 2010 | 05:41 AM
Rudy's Avatar
There are many threads on these boards about this subject. It's usually much more complicated than just an alternator or battery issue and Dandle is correct that the cause it generally a module that's not allowing the car to either go to sleep or stay asleep. Finding out which module is the tricky part and is sometimes difficult for trained BMW technicians (with specialized equipment) to troubleshoot the problem...
Old Aug 13, 2010 | 02:17 PM
nevrev73's Avatar
My Ride: 2008 530d M sport
Check IBS lead (intelligent battery sensor) lead or the battery may not be holding its charge or the car is not going to sleep properly. Check for the orange light going out after one hour by the P on the auto gear shift lever
Old Aug 18, 2010 | 05:31 PM
ressan's Avatar
I was getting the same message. After two days of diagnostics the dealer said that my drivers side comfort accesss door handle was constantly waking up the car. They ordered a new handle and I'm going in next week to have it replaced.
Old Aug 18, 2010 | 09:17 PM
madein's Avatar
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
I had the same problem for 3 weeks - when I was on holiday - every morning when I started the car the message came up - it stop just after I come back to UK - and I believe it was because I couldn't park the car straight left side was higher than right and maybe self leveling suspension tried to level the car?
And I also had the daylight switched ON, which I'm not using in UK - but I can try tonight an let you know.
Old Aug 20, 2010 | 10:29 PM
madein's Avatar
Model Year: 2011
Lights switched ON - no error message - so I believe it was to auto leveling which was discharging the battery in my case.
Awest91
Sep 17, 2022 11:05 PM
DavaiLave
Aug 2, 2022 02:16 AM
audiophool
Apr 14, 2015 03:50 PM
ZeZe
Oct 15, 2003 12:58 PM
