Will these Miro M6 fit my xi?
I'm looking for a set to use on my 07 525xi. I found these locally and was wondering if it will fit my car.
19x8.5 ET35 with a 235/35/19 in the front and 19x9.5 ET33 with a 265/30/19 in the rear.
Currently there are no tires, just rims but owner told me those were the tire sizes he had mounted on the rims.
Thanks in advance!
Thanks in advance!
Yes, wheels will fit no problem OTH the tires are for 3 series setup ... I wouldn't use those 235/265 on an E60 as it'll look narrower and/or skinnier not to mention with less sidewall it'll make the ride more harsh due to E60 weight is heavier.
E60 19" wheel recommended tire setup are 245/35-19 front & 275/30-19 rear like what I'm using (click on the link in my sig for info) but I'd go wider to 285/30-19 on the rear on my next setup to give more meat for extra wheel protection.
GL!
GL!
Thanks BlaSTiWi!
I'll make sure to go with the tire setup you recommended on these rims.
GL!
GL!
BurtonSnol3order
Jul 3, 2015 09:28 PM
