Wheel Offset
I have some nice VMR V710 that I had from my BMW Z4.
Would you guys recommend I put them on my 2006 530i with sport e60?? Will they fit with spacers?
The wheels I have are
Front 19 x 8.5 offset (et) 35
Rear 19 x 9.5 offset (et) 45
The tires need to be changed so I'm open to tire sizes.
Or
Do I sell the wheels and get new ones again (One wheel has a gash on the side, otherwise mint)
Thanks.
Or
Thanks.
My Ride: Bmw 530d 2004
20mm spacers in front and rear. If you end up goinf this route, I recommend spacers that are bolted in the axle and the wheel is attached into the spacer with another bolts.
- Antti -
- Antti -
Or sell them to a forum member with xi / awd and buy a set with the proper offset w/o needing spacers.
How do you come up with the optimal spacer size?
Thanks,
Great info on these sites to figure it all out!
Everything You Ever Wanted To Know About Spacers
http://www.turnermotorsport.com/t-wh...yclopedia.aspx
Wheel Offset Calculator - The Ultimate Stance Calculator
http://www.jonathanrowny.com/page/offset-calculator
Another wheel comparison calculator
http://www.rimsntires.com/specs.jsp
Then, at the rear I've had a 8.5x19 ET14 with a 12mm spacer --> ET2. Comparing that to 9.5x19 ET45 with a 20mm spacer tells us that your wheel would still sit 10mm more in.
- Antti -
asinner
05-06-2015 06:03 PM
