tire size for 20' DPE for 09 528i
Old Mar 5, 2013 | 07:50 PM
deejayjonjon's Avatar
My Ride: 2009///528i///Alpine white///20 inch DPE s20///KW V2 Suspension///
Default tire size for 20' DPE for 09 528i
what up everyone! so i have been searching around for tires for a while, and finally picked some up today. hankook v12 evo (255/35/20 (F) and 285/30/20), which was suggested to me by a local performance shop. I have been reading that 255 fronts will rub against the fender. so my question is....can i roll my fenders to stop rubbing? my car is also lowered on KW V2. any suggestions would help. thanks! apologies if this question is redundant!
Jon
Old Mar 5, 2013 | 09:44 PM
Booyaazaa's Avatar
Jon
The front tire is a bit tall, it should be a 255/30r20 to keep it the right height otherwise you'll rub the top of your fender which rolling won't help. You will need to get the front fenders rolled to prevent rubbing on the side when hitting bumps and the offsets for the front wheels need to be et13 to clear the KW V2 CO. I just went through all this last weekend when I had my V2's installed.
Old Mar 5, 2013 | 11:16 PM
okay coo, thanks Booyaazaa!
I thought it would clear since i previously had 245/30 in the front but when i compared the two , the 255/35 was way more beefier than i expected. i also had to get a 5mm spacer to clear the front coil. thanks for the info!
asinner
May 6, 2015 06:03 PM
SNYPRUSMC
Apr 28, 2015 04:14 PM
lowcg3
Mar 26, 2015 11:23 PM
HS_01
Jul 5, 2004 06:15 PM
Aska
Mar 12, 2004 04:55 AM
