Rims for e60 xi
Rims for e60 xi
Hello.. I have 2010 e60 528 xdrive
Ive just started looking for rims and it's confusing because alot of sites will list rims as
for XI models only... Can anyone tell me why xi rims woudnt fit on regualr rear wheel dirve versions?
Or are these sites just being stupid
Also I wanted a set of Avante Garde M355. Says not compatiable for my car because of the staggered set up. .Why woudnt i just be able to purchase to front sets so they are all the same width?
Please can someone clarify for me. I have no places I can walk into and ask in RI. So if I buy online i need to make sure they will fit.. Thanks
My Ride: 2008 550 sport with all the fixins, 07 yukon with all the fixins.
I'm selling mine that I took off my 08 550 if you are interested. Emaill me if you have any questions. bcoopr1@yahoo.com Boots
Click on link below
https://5series.net/forums/private-m...wheels-129968/
I don't know anything about the other wheel you described.
Click on link below
First about the AWD & RWD wheel ... xi/AWD/x-drive model uses high/big offset (ET) number the same with 3-series (and also the newest F10 5-series) while RWD model uses low/small offset, so if you put xi rims on RWD model the wheel will sit to the inside and may not clear the brake caliper and/or like on the front the tire may not clear the front strut). On the other hand if you put RWD rims on xi model the wheel will stick out and may protrude the fender well may cause rub (and for some undesirable look).
2nd about staggered in which not many understand, xi/AWD/x-drive model have no problem using staggered setup (I've been using staggered setup for over 5 years) what matters is the consistent rolling diameter between the front & rear tire. In your case you should have no problem getting staggered setup Avante Garde M355 just make sure you pick the front & rear set with bigger/larger ET number and of course proper tire sizes or as you already said to keep a square setup just pick all 4 with the front dimension.
There are already many threads here talked about this in detail and you should be able to search them and read thru them if you like to find out more deeper & detail.
GL!
GL!
My Ride: 2008 BMW 528Xi
+1
we have thread here about xi fitment, I read through the whole thing & arrived at the below setup. Note: I have an '08 528xi
Avant Garde M355 Gunmetal with machined face
Front:
19x9 ET35
245-35-19 Hankook Ventus V12
Rear:
19x10 ET38
285-30-19 Hankook Ventus V12
no rubbing & no spacers needed!
Front:
19x9 ET35
Rear:
19x10 ET38
Are you using 10" up front or you mean 9" w/ ET35?
+1
Front:
19x10 ET35
Rear:
19x10 ET38
Front:
19x10 ET35
Rear:
19x10 ET38
My Ride: 2010 535xi M-Sport
GL!
GL!
Info = Wheel Tech - Offset
Offset is fixed to the wheel and some manufacture may have at least 2 of the same look/kind with big/high offset and also with small/low offset number.
Or some design i.e. OEM BMW M5 (style 166) and/or M6 (style 167) only came with low/small offset number for RWD model fitment.
bestofthebest
03-30-2015 08:12 PM
