rear tire size
My Ride: E60
My car is 2006 530i sports with oem m5 wheel. The rear tire size now is 285/30/19. Is it ok to have 295/30/19 for the rear without rubbing fender? Thanks
![Exclamation](https://5series.net/forums/images/icons/icon4.gif)
so you may have clearance but I'm thinking this would "over-tire" your 530 e60.
My Ride: 2008 550i
I went from a 275/30/19 to 295/30/19 on my 550i 172m wheels. The wider rubber protects my rims from the many bad roads we have down here. If the 166m M5 offsets are the same as mine, you will be fine, no fender rolling required.
My Ride: E60
[QUOTE=dingolfing;1513047]I went from a 275/30/19 to 295/30/19 on my 550i 172m wheels. The wider rubber protects my rims from the many bad roads we have down here. If the 166m M5 offsets are the same as mine, you will be fine, no fender rolling required.[/QU
Anybody know if 172m and m5166 wheels have the same offsets.
Thanks
Thanks
