Oem m3 rims
I have a 2004 325ci convertible coupe and I'm planning on putting m3 18x8.5 rims on it and I would like to know if I put tires size 215/35/18 all around bcuz my setup is 18x8.5 all around would it rub or will I have plenty of clearence.......any advice would be greatly appreciated
Do you happen to know the wheel style? If you don't, check here: All BMW wheel styles 3 | BmwStyleWheels.com
Knowing the offset will help to give you an answer. You can also plug your specs in here: Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit |
Oem m3 rims
I purchase a set of the style 67 and the writings on the inside of the rims is marked ET18 and 8.5JX18 H2....I'm planning on putting 215/35/18 on it
