Oem m3 rims
Old 02-21-2017, 03:34 PM
Charles04's Avatar
My Ride: 325ci convertible
Default Oem m3 rims
I have a 2004 325ci convertible coupe and I'm planning on putting m3 18x8.5 rims on it and I would like to know if I put tires size 215/35/18 all around bcuz my setup is 18x8.5 all around would it rub or will I have plenty of clearence.......any advice would be greatly appreciated
Old 02-21-2017, 05:16 PM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
Do you happen to know the wheel style? If you don't, check here: All BMW wheel styles 3 | BmwStyleWheels.com
Knowing the offset will help to give you an answer. You can also plug your specs in here: Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Old 02-21-2017, 05:48 PM
Charles04's Avatar
Default Oem m3 rims
I purchase a set of the style 67 and the writings on the inside of the rims is marked ET18 and 8.5JX18 H2....I'm planning on putting 215/35/18 on it
tpaxadpom
01-30-2017 08:55 PM
E60dreams545
01-28-2017 07:17 PM
Gwentuken@gmail.com
04-05-2016 10:25 AM
bestofthebest
04-02-2016 11:07 AM
Presley348
04-16-2006 05:39 AM
Quick Reply: Oem m3 rims
