need help with tire size.
Old May 28, 2013 | 09:53 PM
aznfujikiddd's Avatar
My Ride: 535
Default need help with tire size.
I recently purchased a set of 20s , 20x9 et20 front, 20x10.5 et20 rear, and I had 08 535i sports package. I need proper tire size without rubbing ..thx for your help.
Old May 29, 2013 | 08:55 AM
according to rolling diameter tires should be 245/30/20 and 285/25/20. we usually recommend thicker sidewall sizes and if you were to rub you can always get the fenders rolled.
Old May 29, 2013 | 03:06 PM
My Ride: 535
Im thinking to put on 245 35 20, 275.30 20, will it rub?
Old May 30, 2013 | 08:53 AM
most probably it will for the fronts, rears is a maybe as you would be having a thicker sidewall but also stretching since 275 is a lower width. if you were to rub though you can always get the fenders rolled.
Margal
Jun 12, 2015 01:12 PM
mrshy333
Jun 8, 2015 12:17 PM
Gizmo
Lounge
Jul 16, 2004 05:15 PM
HS_01
Jul 5, 2004 06:15 PM
