Leaky rims anyone?
Just curious how many of you are having issues with your 10 or so year old alu rims not holding air.
Got me an apt with Costco tomorrow to fix mine as since they installed my new Pilot Sports last spring got me leaky rims ever since and they say it,s because rims are now over ten years old and they corrode loosing their seal around the rim, maybe so but then again old tires were just fine and my E 39 rims were much older and never had an issue like this either so I think they are BS'n me....... |
I don't buy that argument. Your rims are made of Al and any corrosion is just Al oxide. That is easily cleared off with a ScothBrite pad or similar.
Do you have new valve stems? Do you maybe have a nail you haven't discovered yet? Maybe the last installer used crapy valve stems or didn't change them. Maybe the last installer skipped using the bead sealer when mounting the tires or waited too long after applying the sealer before mounting the ires on the rims. I have a 10 year old e60 and my rims hold air fine all the time. |
Originally Posted by twh
(Post 1562104)
Do you have new valve stems? Do you maybe have a nail you haven't discovered yet? Maybe the last installer used crapy valve stems or didn't change them. Maybe the last installer skipped using the bead sealer when mounting the tires or waited too long after applying the sealer before mounting the ires on the rims. I have a 10 year old e60 and my rims hold air fine all the time. They re-sealed all 4 today and put new stems on so keep my fingers crossed. |
