Help.. what wheel size 19in or 20in and why? Or why not?
My Ride: BMW 550I BLK
Engine: N62
19s or 20s. Im currently sitting on 19 inch stagger wheel setup with stock suspension, im about to upgrade my suspension to the koni yellows w/ the eibach pro kit and i was thinking about going with the 20 inch stagger set up. Is this a good, bad or ugly idea for a 07 550i base model? Harsh ride? Fender issues? Poor handling? Pls comment
If you stick with the outside diameter of the stock tire, you'll be at 25 or 30 profile on a 20" rim. I'm using 40 series on 18" now, and IMO anything lower is less attractive. The larger the rim diameter, the more rotational mass you have, which affects acceleration and braking.
Engine: N62
20' will be very hard from the low profile needed to run the 20's. The 7 runs factory staggered 19' that would ride much better you can put 21's under there!
