Help.. what wheel size 19in or 20in and why? Or why not?
19s or 20s. Im currently sitting on 19 inch stagger wheel setup with stock suspension, im about to upgrade my suspension to the koni yellows w/ the eibach pro kit and i was thinking about going with the 20 inch stagger set up. Is this a good, bad or ugly idea for a 07 550i base model? Harsh ride? Fender issues? Poor handling? Pls comment
If you stick with the outside diameter of the stock tire, you'll be at 25 or 30 profile on a 20" rim. I'm using 40 series on 18" now, and IMO anything lower is less attractive. The larger the rim diameter, the more rotational mass you have, which affects acceleration and braking.
Originally Posted by audiophool
(Post 1588786)
well the only different the i fell between 19 and 20 is the price of the tires. 19's are more expence and hard to find it
Originally Posted by kennethm2v
(Post 1589322)
20' will be very hard from the low profile needed to run the 20's. The 7 runs factory staggered 19' that would ride much better you can put 21's under there!
