Help with offset and TSW Rims
Old Oct 19, 2015 | 08:44 PM
shervinj's Avatar
My Ride: 530i
Model Year: 2005
Default Help with offset and TSW Rims
Hi Guys,
I have an offset question I need some help with. Currently have 2005 530i with the stock style 138 rims, offset of et 20, Square set up. 225 50 17 tires.
I found a guy selling rims with new tires for less than buying a set of new of tires for my car. The specs for the rims are
TSW Tanaka matte black
Front 18x8.5
Rear 18x9.5
Offset ET 15
I did the will it fit check and it told me this:
Front Wheels
Original New
Diameter 656.8mm 637.2mm
Circumference 2063.4mm 2001.8mm
Poke 75.3mm 93mm
Inset 115.3mm 123mm
Speedo error 0% 3.08%
Reading 30mph 30.92mph
Reading 60mph 61.85mph
Ride height gain0mm -9.8mm
Arch gap loss 0mm -9.8mm
Compared to your existing wheel, this new wheel will have an inner rim which is 7.7mm closer to the suspension strut. The outer rim will poke out 17.7mm more than before.
Rear Wheels
Orignal New
Diameter 656.8mm 628.7mm
Circumference 2063.4mm 1975.1mm
Poke 75.3mm 105.7mm
Inset 115.3mm 135.7mm
Speedo error 0% 4.47%
Reading 30mph 31.34mph
Reading 60mph 62.68mph
Ride height gain0mm -14.05mm
Arch gap loss 0mm -14.05mm
Compared to your existing wheel, this new wheel will have an inner rim which is 20.4mm closer to the suspension strut. The outer rim will poke out 30.4mm more than before.
Is how much it is closer to the strut and how much it pokes out seem normal for aftermarket rims? I know the e60 rims has kind of an odd offset and can't use a lot of the 3 Series and new 5 Series rims.
Will these work?
Old Oct 20, 2015 | 06:02 AM
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
Will these work?
You can't make sweeping generalizations about aftermarket rims because you can buy aftermarkets with the exact dimensions of your OEM wheels. It just depends on whether you choose to or not and whether the style you like comes that way. How much the wheels poke out is personal preference. Closeness to the strut can be corrected with spacers, as many here use.
Old Oct 20, 2015 | 08:35 AM
shervinj's Avatar
My Ride: 530i
Model Year: 2005
Yes I understand that and I appreciate you replying.
These are used so I was trying to see if they were compatible and would not cause any immediate issue. If I bought rims new I would go for the best match available.
If I put these on as is, would they be to close to the strut?
They are wider than the stock set up. If spacers were required, would that push it out so far it would be problematic?
Old Oct 20, 2015 | 03:48 PM
shervinj's Avatar
My Ride: 530i
Model Year: 2005
my friend said he didn't like how much these tires were stretch and advised me to pass on them.
lowcg3
Apr 11, 2015 02:57 PM
ZeZe
Oct 15, 2003 12:58 PM
das
Jul 6, 2003 02:09 PM
RichReg
Jun 20, 2003 06:29 AM
Jun 17, 2003 09:38 PM
