Help needed for '04 E60 rim and tyre choosing
Old Mar 14, 2015 | 10:58 AM
bananfiu's Avatar
My Ride: '04 E60
Arrow Help needed for '04 E60 rim and tyre choosing
Hi guys!
I am pretty new here, and I would like to ask your advise. I have a stock 2004 BMW E60 530d, and I would like to change the rims.
I have picked these:
Amazon.com: Verde Custom Wheels Saga Wheel with Satin Black Finish (20x8.5"/5x120mm): Automotive Amazon.com: Verde Custom Wheels Saga Wheel with Satin Black Finish (20x8.5"/5x120mm): Automotive
Will they fit my ride? If yes, should I buy 4 of these, or do I need different size for the rear and front 2-2? Same questions is going for the tyres.. Which should I pick, and what sizes?
I live in Hungary, and we have kind of bumpy roads. Will these rims+tyres rub?
Will these change driving security?
I hope you can help me guys, and sorry for the bad English!
Thank You!
Old Mar 14, 2015 | 11:09 AM
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
...Moving this to the Tire and Wheel forum...
You might find some answers to your questions here: Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit. The vendor should also be able to advise you on the correct sizes for their wheels. It's called a "staggered setup" when you have larger wheels in back than in front. It's purely an appearance thing. You don't have to do that.
Your English is just great! My Hungarian should be so good (nonexistent).
Welcome to the forum!
Old Mar 14, 2015 | 11:12 AM
bananfiu's Avatar
My Ride: '04 E60
Thank you really much jayarras! I am going to check out that you have linked. And thanks for the greeting, I am glad that I have found this forum.
Old Mar 14, 2015 | 01:19 PM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Welcome to the forums!
Sorry to tell you the wheels you linked won't work without spacers that push the wheels more out from the wheel arch. They would need hubcentric rings too, because the center bore seems to be 74.1mm.
The correct measures for the e60 (RWD) would be 8.5x20 and ET/Offset 20 or less. The correct center bore is 72.56mm.
- Antti -
Old Mar 14, 2015 | 02:08 PM
bananfiu's Avatar
My Ride: '04 E60
- Antti -
Thank you! Very useful info!!!
bestofthebest
Mar 30, 2015 08:12 PM
MartinF
Mar 27, 2015 05:52 PM
ZeZe
Oct 15, 2003 12:58 PM
das
Jun 2, 2003 03:55 PM
