e60 spacers?
Old 07-29-2014, 02:55 PM
c.a.r 525i's Avatar
My Ride: stock 04 52i
Default e60 spacers?
Ok guys I'm new to all this and been searching but I'm still asking my self some questions.
First off I just installed d2 coilovers and 7 series rims 19x9+24
And 19x10+24. as soon as I dropped it the front tires started to rub on the coilovers so I raised it back up. I got 5mm spacers just to see if I drop it again it will solve the problem its still close to coilover I was wondering if anyone had this experience before and just kept the 5mm spacers and have had no problems rubbing. I have 245/45/19 front tires . And my second question might sound dumb but here it goes. So if I have 24 offset and get 10mm spacers will the rim be considered a 14 with the adapters?
Old 07-30-2014, 11:49 AM
that is correct about the spacer and offset. if the offset of the wheel is ET24 and you put a 10mm spacer on, it would be ET14. also your tire size should be 245/35/19 for the front according to specs.
Old 07-31-2014, 11:43 AM
c.a.r 525i's Avatar
Ok so if everything clears with 10mm spacers and I get no rubbing issues does that mean that if I was to get new rims with 14 offset I wouldnt need spacers?
Nihilation
07-10-2022 11:32 AM
KLR4LIFE
04-01-2015 10:38 AM
lowcg3
03-26-2015 11:23 PM
Virak1985
03-09-2015 06:05 PM
ZeZe
10-15-2003 12:58 PM
Quick Reply: e60 spacers?
